The next thing to try is to clear the CMOS. Please follow these instructions exactly.
Remove the power cable from the mains supply and then press the power switch on the case for 10 seconds just to drain any residual energy in the PSU capacitors.
Once done remove the motherboard battery for at least one hour before replacing it.
Next plug back into the mains supply and boot.
You will now need to enter the BIOS/UEFI by pressing DEL and load Optimised BIOS Defaults.
Make any other changes to the BIOS settings to suit your self like disabling the floppy drive, disabling the full screen logo and making the HDD the primary boot device and then press F10 to save and exit.
Stolen from another forum but sound advice all the same.
