New build - Please help
13 Dec 2020
Cambridge
Hi all.
I'm currently putting together a new build but I came across a question, what RAM should I add to the following setup:
- MSI b450 Tomahawk max
- AMD Ryzen 5 3600
- RAM ? (2x8GB)
Was thinking about 3600mhz, but seems to be something difficult to get within my budget range £100.
Can someone help here?
Hi all.
- AMD Ryzen 5 3600
- RAM ? (2x8GB)
https://www.overclockers.co.uk/cors...zen-tuned-ddr4-memory-dual-kit-my-4bw-cs.html
https://www.overclockers.co.uk/patr...dual-channel-kit-pvs416g360c8k-my-104-pa.html
https://www.overclockers.co.uk/team...-3600mhz-dual-channel-kit-blac-my-0a3-tg.html
https://www.overclockers.co.uk/king...l-channel-kit-hx436c17pb4k2-16-my-28e-ks.html
https://www.overclockers.co.uk/king...00c17-3600mhz-dual-channel-kit-my-299-ks.html
https://www.overclockers.co.uk/king...00c17-3600mhz-dual-channel-kit-my-29a-ks.html
All on offer at the moment, some even with RGB and also all below £100 :)
@Space Monkey what's better within my budget to work with b450 motherboard?
- CL 16 @ 3200
- CL 18 @ 3600
I think the latency works out about ~10ns for both but I'm not sure about which one to buy
