Hi,
Just finished assembling my new rig, everything's all connected up correctly AFAIK, however when I turn it on it only stays on for 4 seconds, cuts out, then powers up again, until I power it off. Also, the case fans spin, LEDs light up, but the CPU fan doesn't do anything but a small twitch
Specs:
Mobo: Gigabyte Z68X-UD3P-B3
CPU: Intel i5 2550K
RAM: 8GB Corsair XMS3
GFX: Inno3D 560Ti 448 core
SSD: OCZ Agility 3 60GB
PSU: Corsair HX620w
Case: Bitfenix Shinobi black windowed
ODD: LiteOn somethingorother DVDRW
Case fans: 2 x 120mm Xigmatek Crystal white LED, 1 x Xigmatek XAF-140 PWM 140mm white.
Could it be that I've connected the 140mm fan to the "PWR_FAN" 4 pin port? (I connected it there as that was the only 4 pin available on the mobo, the other 2 are 3 pin)
Halp
P.S:
The PSU has been used in another system so it's not that, as has the graphics card. Everything else is new/second hand.
Specs:
CPU: Intel i5 2550K
PSU: Corsair HX620w
Halp
P.S:
Hoping that's the problem!
. I think the older CMOS chips held their charge for quite a bit longer due to the materials used, but with modern board's I've found even 30 seconds is often enough to get a clean wipe, but a few minutes isn't exactly a long time to wait, good excuse to make a cuppa if anything.
