- 3 Sep 2008
I built a new system :
Asus P8P67
Intel i5 2500
G.Skill 8GB (2x4GB) 1600mhz 9-9-9-24 1.5v
Coolermaster RealPower 700w PSU
Nvidia 210
and whenever I power on the system it will either come on for a second or 2 then power off and then power itself back on again and work fine
or
when I power on all the fans and things startup as normal but I dont get the system beep and nothing happens so I have to hold the power button in to switch it off, then when I power up again it says overclock failed, even though I dont want to overclock and all the bios settings are set to default.
Any ideas whats happening? Ive tried manually setting the RAM voltage to 1.5v and timmings to 9-9-9-24 -2N but still get the same problem.
Help would be very much appreciated!
Asus P8P67
Intel i5 2500
Nvidia 210
or
