Hi All,
I've just built the following spec:
"Primo 510i" Intel H61 DDR3 Ready Barebones (Socket 1155)
http://www.overclockers.co.uk/showproduct.php?prodid=FS-278-OK&groupid=43&catid=2213&subcat=
TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit
http://www.overclockers.co.uk/showproduct.php?prodid=MY-020-TG&groupid=701&catid=8&subcat=1517
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM
An Intel i3 2120 (3.3ghz) off MM
1TB Hard drive off MM
Now i've just put it all together. Sometimes I can get into the Bios, but usually it just powers down before it even posts. When it does post, all is normal.
In the Bios, everything shows up correctly. CPU temp is around 43 degrees C, so thats OK.
It just does a constant loop. Starts up to the point where you can hear the HDD start to spin, then shuts off, then starts up, then shuts off etc etc.
I've tried with no HDD, One stick of ram etc etc. On the odd occasion i've managed to get to the windows setup screen, but then its shut off.
Short of sending the whole bloody lot back apart from the CPU / HDD, i'm not sure what to do!
Any idea's?
Many Thanks
James
Any idea's?
Many Thanks
James
