- 25 Aug 2004
- Chester, England
Hi, I'm currently at a friends house building a newly purchased PC from OcUK.
Spec is an E6300, ASUS P5B-E Plus, 2GB of OCZ PC-6400 RAM and a BFG 8800GTS, Enermax Infinity 620W PSU, Antec 900 case, Tuniq Tower, 2 Western Digital HDDs.
Have put all components together put the computer is failing to display anything on the screen of the LCD TV monitor that we are using, the monitor has worked previously so should be no issues there.
Only difference is that since the 8800 has 2 DVI connectors, a VGA-DVI converter is being used.
When the PC powers on there seems to be no problem but "No PC input detected" shows on the screen.
Any ideas anyone? Anyone have a similar setup that is working?
Thanks, LS.
Thanks, LS.
Can you borrow a speaker from another system?
