New Build problems with Power supply and Ram
5 Mar 2009
Hi,
It has been a while since I last build a PC and I think I order a few wrong items. Could someone confirm for me please?
The main issue is I ordered the Corsair TX 750W ATX SLI Compliant Power Supply (CMPSU-750TXUK) - on a recomendation. However it doesn't seem to have the 4 pin 12 volt power for the CPU. Am I missing something does one of the conectors transform or do I need to buy a new one?
The motherboard I got was the Asus p5n-d.
The other question is can I run 1066hz Ram on a board that only supports up to 800mhz? Not too worried about overclocking it just yet but will it just run at 800mhz or do I need to change that too?
Feeling dumb and it is really late :P
Thanks Guys!
Just FYI I got one GTX 260 card as I plan to do some Nvidia 3d gaming and was thinking about SLi later hence the board/card and high power.
The PSU should have an EPS/ATX12V 8-4 pin cable like this
which you can "split".
I think your memory will function, but obviously only at 800Mhz.
