cpu 2160
abit ip35
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-6400C4 800MHz
samsung sp 400gig sata
corsair 520 psu
ide dvd rw
1st: twice I have had to clear cmos to get rid of the error (cpu unworkable or changed)
2nd: when try to install vista I have had to connect a PS2 keyboard! usb keyboard wasn't working when asking to press any to boot from cd/dvd! but i was able to get into the bios with the usb keyboard.
3rd: when installing vista load the stand vista pic but then take about 4/5mins to get to the gui (where you select what language you wanna use etc)
the pc just sits there doing nothing, dvd stops spinning and 4/5mins later it kicks in again. tested the disc, dvd drive and cable on my old my and it works as normal.
taken from bios:
cpu temp 29
sys temp 28
pwm temp 36
cpu core 1.29v
ddr2 1.79v
cou vtt 1.20v
+12v = 12.08v
+3.3v + 3.28v
gonna up the RAM voltage and try it again!
abit ip35
corsair 520 psu
ide dvd rw
taken from bios:
cpu temp 29
sys temp 28
pwm temp 36
cpu core 1.29v
ddr2 1.79v
cou vtt 1.20v
+12v = 12.08v
+3.3v + 3.28v
