- 1 Sep 2007
- St. Helens & Blackpool
Hi I've just put together a PC,
Asus P5E, E7200, WD640gb HDD, 2g pc6400 ram.
It turns on ok and lets me Instal Windows (XP), then when i try install the Motherboard CD after it shuts down to restart, it doesnt it open up a DOS like window with the following message writen in it.
FreeDOS kernel version 1.1.35w (Build 2035w-UNSTABLE, Nov 30 2005)
Kernel Compatibility 7.10 - WATCOMC - FAT32 support
Copyright 1995-2005 Pasquale Villani and the FreeDOS Project
NO WARANTY. Licensed under the GMU General Public License version 2.
C: HD1,Pri[ 1], CHS= 0-1-1, start= 0 MB, size= 31MB
then after a while this appeared under it:
Bad or missing Command Interpreter
Enter the full shell command line:
command.com /p /e:256
Any help would be greatly appreciated.
