new build problems
18 Dec 2010
hi all,
i have had so many problem with this new homebuilt system.
what the problem is:
the system works how it should with one module but with two modules it get to the windows 7 logo and reboots.
i have tried every slot with each module on there own and both work fine.
but once both modules are in it reboots, i have tried all variations and now stuck to what to do.
i have replaced the memory 3 times this is my second motherboard i have tried another hdd and odd but still no luck.
i have even tried setting the speed, timings and voltage to what is on the memory stick but still no luck.
any help will be great
thanks in advance
no it is different memory, i had some corsair cmd sent out but it was for intel cpu's so i sent it back and ordered some corsair cmp that is phenom II compatible and bemp.
system phenom II 965 be
asus m4a88t-m
corsair cmp 2x2gb 1600mhz running 1333mhz
xfx 650w core edition 53a +12v
asus gtx460
antec 902
the board has 4 slots 2 black and 2 blue
black slots = a2/b2
blue slots = a1/b1
the manual states to put dual channel memory like the ones i have got in the blue slots a1/b1 so i have tried that and all other variations.
but still no luck
