Hello to everyone
I built a new 4k computer May 2017
The main three problems I had was
1. No beeps on my computer because my case was the Corsair Air 740 and it didn't have a speaker cable to add it to the motherboard,
2. The Debug LED code was 'CO' but in the motherboard book code it says 'Reserved' ?
3. On boot up a red light on my motherboard that kept coming on it was the vga light only
Because my computer case didn't have a speaker so I added one from old computer to hear the beep codes, so on boot up there was two beeps and the 'CO' led also the red vga light was on so I turn off the computer,
I check all the cables took out my GTX 1080 TI card and put it back in but the still the two beeps and the vga red light and 'CO' code led was both on so I turn off the computer again,
I used my laptop to search online for the problem but what I found was many talk about it was the memory sticks, PSU, Can't open the Bios, Motherboard, can't open Windows 10 problems but none of these was the problem for me and nothing about the Debug code but still it boots up and I can open the Bios and it loads Windows 10, also I can play games.
Then I found a website for the Debug code from Gigabyte website it just says this is for "Reserved for future codes"? I was confused, I also found a website for the beep codes and information to fix the red light problem I turn off the PSU and unplug the power cable and press the "COMS_SW: Clear CMOS Button" on the Z270X Gaming 7 motherboard,
I waited just five minutes and plug in the power and turn on the computer then the computer shut down and restart and I went into the Bios and change a few things then the computer shut down again and restart it self then I hear only one beep code and Windows 10 loaded the red vga light was gone, but still the 'CO' code was on strange!
But now I turn on the computer I don't hear any beep codes again on the boot up but everything is running ok on a SSD drive.
So is it the Motherboard? That is the question I would like to ask any of you in your own opinion,
Thank you for taken the time in read this Thread
