- 7 May 2017
Hi guys wondered if you could help, i recently brought several components to build a new pc and am having trouble with the GPU. When i am connecting it to the monitor is has a connection as no warning message comes up saying there is no signal but all i am getting is a black screen.
I tested the system with my brothers old GTX770 card it posted straight away. I was wondering if:
A) the PSU is too low a Wattage to run everything? but the fan was running round the GPU when it was installed so not sure. I used https://outervision.com/power-supply-calculator to check first and it said i only need 380W
B) if it is a faulty card? The card was B-Grade but i know my brother has brought plenty of components from clearance and has never had a problem.
my current build is:
AMD Ryzen 5 Quad Core 1500X 3.70GHz (Socket AM4) Processor - Retail CP-3A0-AM
**B Grade** OcUK GeForce GTX 1060 "Reference Design" 3072MB GDDR5 PCI-Express Graphics Card
Corsair Value Select 8GB (1x8GB) DDR4 PC4-19200C14 2400MHz Single Channel Module
Asrock AB350M AMD B350 (Socket AM4) DDR4 Micro ATX Motherboard
BitFenix Comrade Midi-Tower - Black
Kolink KL-500M 500W 80 Plus Bronze Modular Power Supply
I am also using an old Kingston 120GB SSD that may brother gave me as the Hard drive
