I posted on the corsair forum about this too, so I'll put the same here. I have no idea what to do with it now. I've never encountered a problem like this before:
Not much activity over on the corsair forum so maybe someone here can help me
Ok, im completely stumped.
I have Asus p5q-e updated to latest bios, 64bit vista and 8gb (4x2gb) of 6400c4dhx.
I set it up all normal with 2 sticks in and 800mhz 4-4-4-12 2.1v and it works flawlessly.
I put 4 sticks in, move it down to 667mhz and up the NB voltage and the system just completely sucks. Takes about 10 minutes to get into windows (its a clean install) once in windows everything is juddery, the cpu is at almost constant full usage (may be windows trying to figure out whats wrong though, not sure) yet the memory usage is at about 1gb.
Bear in mind its not the windows instal, as it works fantastically with 4gb in.
Does anyone have any possible suggestion as to what might be the cause?
While waiting for replies im gonna try run 3 sticks to see how that boots. I will update shortly.
Help!
Ok, just tried with 3 sticks. Took two out and tried them both individually in both free slots. So stick3 in slot 2 and 4 and stick4 in slot 2 and 4.
Each time exactly the same. Windows runs rediculously slow (didnt actually get into windows on any of the attempts. Its pretty obvious after 1 min loading something is wrong when it is in windows in about 20 seconds max with 2 sticks.)
I cannot possibly thing what the problem is. Doesn't seem to be the ram slots as tried both. Doesnt seem to be the ram itself as I have tried swapping them all around, its only when there is 3 or 4 sticks in that the problem happens.
