New build randomly freezing
4 Dec 2012
Hi all, about a year and a half ago I built a new pc and have had constant problems since building (only just got round to trying to sort it)
The build is this;
https://www.overclockers.co.uk/reco...o-six-core-value-gaming-bundle-bu-231-ok.html
With a MSI Radeon R7 360 Gaming 2048MB GDDR5 PCI-Express Graphics Card
The OS is Windows 10 x64, which is booting from a Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive.
I have built a few computers before, and this is the first issue like this that i have come across.
The freezing happens randomly, and no logs are produced. Sometimes it happens under load, sometimes it happens just whilst on the desktop. I have stress tested it before to try and replicate the issue but nothing has happened.
It's becoming quite a chore now to the point it is barely used as when it freezes I have to do a hard reboot every time.
I have already swapped out the old power supply thinking it could be that, but to no avail. I can't remember the power supply that is currently in, but I will find out if needed. I'm stumped. Any advice?
Thanks,
Xerse
Is it overclocked? Have you tried running one stick of ram only/use different slot? ssd error checked/use different cable/port? bios updated? settings correct in bios voltages/timings etc? tried a fresh install of windows? drivers upto date? Tobe honest it could be anything could even be something plugged in via usb like the mouse or sd card reader.
