Hey All,
I am having a bit of a strange issue with my son's new build.
the PC boots up fine with no issues but when either idle or being used to play a game it will randomly reboot (not shut down.
The specs are below
My basket at Overclockers UK:
PSU is a Corsair 430W modular PSU. I know this is fine as have had this running in my main PC for a good 6 months with no issues which is a I7 950, 6GB of ram Asus X58 mobo, 3 x SSds and a 390.
So far I have done the following
- A full clear of the CMOS and left everything on default
- Re connected the 24 pin and 8 pin connector to the mobo
- Replaced PSU kettle lead
-Loosened off the cooler to make sure this was not too tight
- Memtest ran for 9 hours with 9 passes
I do have a loan CPU from AMD which is a A6 9500 which I got as a boot kit that i can try it on but I do not have any other ram to test with
in event viewer I get this
I can change the PSU over with a 750w PSU and I can try the A6-9500 CPU while I still have it. does anyone else have any other suggestions to try? I get this twice a day, sometimes once.
The specs are below
- 1 x Raijintek Arcadia Mid Tower USB 3.0 Case - White= £26.99
- 1 x Team Group Vulcan T-Force 8GB (2x4GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD48G3000= £74.99
- 1 x AMD Ryzen 3 2200G VEGA Graphics AM4 CPU w/ Wraith Stealth Cooler= £94.99
- 1 x Gigabyte GA-AB350M-Gaming 3 AMD B350 (Socket AM4) DDR4 Micro ATX Motherboard= £72.95
