New Build restarts after 10 seconds
Permabanned
21 Apr 2008
im using a 4670K and a Gigabyte z87n itx board, I turn it on it posts no video, then resets every 10 seconds, also this board has no speaker so i get no beeps
:confused:
Run Memtest with both ram sticks in. If you get errors then you know it's faulty for sure. (though sounds like it from your description already)
managed to get memtest86 to run on the iffy stick of ram, it went for about 5 mins then crashed memtest then went into a bootloop?
the other stick works fine in both slots, and have managed to install windows 7 and more while using it
surely that makes it ram?
Try the faulty stick in both slots, I've had a similar issue (But both sticks work independently of each other, just not together), OC replaced the RAM but it's still happening unfortunately, I think it could be the motherboard at fault. OC said it could even be the processor. So it's all had to go back! :(
I think if one stick works in both slots, and the other doesn't work in either of the slots it's a fair assumption that the RAM is at fault.
