- 13 Mar 2006
I've just built my first pc and I'm a bit worried it's running too hot as it's idling at 45c (from the bios). It's an e4300 at stock on an asus p5b vanilla, with a zalman 9700 HSF with Tuniq TX-1 thermal paste, with 2gb RAM, an x1900xt with a zalman zf-9 cooler and 2 hard drives, in a lian li pc7 case with 3 80mm silenx ixtrema 80mm fans and an enermax noisetaker 600w psu with a 92mm and an 80mm fan. All the fans are set to maximum, and taking the side off the case only lowers the temperature to about 41/42C. The motherboard temp from the bios is 38C and the temperature in the room is probably about 27C I would think. Is it likely the HSF isn't seated properly? (it still seems able to swivel round on the cpu), and if I should reapply the thermal paste is there an easy way to spread it to make sure it's even? Any help would be really appreciated!
