- 2 Jan 2011
- Bristol
Afternoon all.
Been away from PC gaming for awhile now and really need to update my existing kit which has been collecting dust for the last couple of years.
My current rig at present is as follows:-
Processor (CPU): Intel Core 2 Q6600 (Stock)
Motherboard: Gigabyte GA-946GMX-S2
Memory (RAM): Unkown brand 2GB (2x1GB) DDR2 PC2-5300 (333MHz)
Hard drive: Samsung SpinPoint HD501LJ 500GB SATA 16MB Cache
Graphics card: Nvidia 9800GT 1GB PCI-E
Power supply (PSU): Generic 355w PSU
Case: Generic, cramped case thats better off as an oven
While this was great about a couple of years ago is really showing its age now.
I'm looking to build from scratch and have a few components in mind but would really like the advice of you guys here as you all seam to know your stuff, plus other opinions are always welcome.
The only items I think worth grabbing out of my old PC is the HDD and DVD drive other than that I'm looking to spend in and around £1,500, although not in one go but get a few items each month as not to get an ear bending spending a fortune
I've got my eye on these items so far:-
Processor (CPU): Intel i7 950
http://www.overclockers.co.uk/showproduct.php?prodid=CP-344-IN
Motherboard: Nothing set in stone just yet but did see these 2 on offer which both have good reviews
http://www.overclockers.co.uk/showproduct.php?prodid=MB-429-AS&groupid=701&catid=5&subcat=1692
http://www.overclockers.co.uk/showproduct.php?prodid=MB-319-AS&groupid=701&catid=5&subcat=1692
Memory (RAM): Also nothing set in stone just yet but something in the region between 4Gb - 8Gb though more than likely plump for 6Gb.
Graphics card: To start I'll probably get an EVGA GTX 480 but eventualy would be after a second to run in SLI after seeing a friends 3d setup and him showing off some Physx stuff.
Regards to the case and PSU I'd ideally like to get these 2 items first but not too sure what case would be best and how big a PSU I'd need. Granted bigger would be better on both fronts. Also dont know what's the best route to go down regards to cooling seeing as I eventually plan on having 2 cards in there I don't know if going water cooled would be best hence why I'm not to sure on the case either as would need a fair bit of room I assume.
As I said got a rough budget around £1,500 so any ideas or advice would be much appreciated.
Many thanks Doug.
.I've got my eye on these items so far:-
Many thanks Doug.
