Hey all,
Got my new system built and working but I have a couple of questions
1) The motherboard tempreature is showing as -1C or 31F any ideas whats going on there?
2) I Have set the XMP settings to "Profile 1" so that the memory runs at 1600Mhz, is this the correct method as it was only running at 1300Mhz before?
3) While windows XP was installed the CPU sat at 1.6ghz 95% of the time, having installed Windows 7 it shoots up to between 3.3Ghz and 3.7Ghz quite a lot, is that normal?
4) On the above subject, I have not overclocked the CPU yet, it is rated 3.3Ghz, why does it run at 3.7Ghz under load?
5) The CPU idles at around 35 - 40C, and seems to hit about 45 - 48C under load is this ok for overclocking? Aiming for around 4.5Ghz
6) Should I be using the "Intelligent Energy Saver" mode of the Asrock software? It reduces the Core Voltage a fair bit and makes the CPU run cooler, but is it safe for overclocks? An Exampe, right now it is sat at 1.6Ghz, using 0.888V.
Then the big one:
7) How do I go about overclocking? I notice there is an automatic "Turbo Mode" where I can select 4.6Ghz should I be using this or just set the mutiplier to 33? Also in the Maximum Core Voltage it has "150" written by default.... What should I set this to? Mostly I am worried about setting up the VCore, I do not want to be frying my chip!
Thanks guys!
Jcb33.
Then the big one:
Thanks guys!
Jcb33.
) should have dropped it down a notch to 1.35 instead tho I think 1.38v is fine.
