My PC is about 3 years old now, so looking to put together a new one.
System will be primarily for gaming, and want it to last at least another 3 years.
Budget is around £1000-£1500 so,
- Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Nehalem) (Socket LGA1366) - Retail - £211.99 inc VAT
- Asus Rampage II Extreme Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard - £252.99 inc VAT
- Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel - £117.99 inc VAT
- Prolimatech Megahalems Performance CPU Cooler (Socket 775/1366) - £49.99 inc VAT
- Sapphire ATI Radeon HD 5850 / 1GB GDDR5 / PCI Express 2.0 / Graphics Card - £219.99 inc VAT
- Kingston SSDNow V+ Series 64GB 2.5" SATA-II Solid State Hard Drive - £134.99 inc VAT
- Western Digital Caviar Black 640GB SATA-II 32MB Cache - OEM - £48.99 inc VAT
- Antec 1200 Full Tower Case + Antec CP 850W Modular PSU - £199.99 inc VAT
- Sony AD7241S 24x DVD±RW SATA Dual Layer & RAM Burner + LightScribe Black Bare Drive - OEM - £18.68 inc VAT
- Microsoft Windows 7 Home Premium - 64 Bit - £72.12 inc VAT
That all comes to £1327.72 inc VAT
Is it worth spending an extra £90 for a HD5870 instead of the 5850, Possibly even a Sapphire 5870 Vapour-X for £339.99?
Would you recommend any other alternatives to what I have selected?
Is overclocking a system like this "Fairly Easy" and Do-able for a someone who has never overclocked before?
Is the PSU Ok?
Also, I have always gamed with a CRT however now i am considering getting a TFT if its not too expensive. As a gamer i am not too fussed about the detail of graphics, but i want very good frame rates, and very smooth gameplay as i play fast paced games. Does a CRT limit performance at all ? Id prefer to keep my CRT as its cheaper, as long as its not holding back my 5850, I've had bad experiences with TFT's being slightly blurred when moving around rapidly. Otherwise what is a good TFT you would suggest 19"-22" for around £150?
All opinions and ideas are welcomed,
Thanks in advance, Will
Is the PSU Ok?
However i have just fixed my personal PC so there is no rush at all now. Cant believe it was all to do with one setting in the bios =/ had be stumped for 2 weeks
