New build sorted, potential issue
2 Jun 2014
New build is running great, only problem is my Zotac 1060 mini is running hotter than before. My b grade mobo didn't come with a backplate for the inputs, which means the back is pretty open. I have two 140mm intakes at the front and one 140mm exhaust at the top. The gpu is running at 83 on bf and dying light, but touched 92 before I set a fan curve.
Front
I thought the two intakes would push all the warm air out of the back, but clearly not. Any ideas?
What case?
Defo need an exhaust fan on the back/and or one in the top :)
I have one 140mm exhaust on top but it doesn't look like it's spinning very fast, I think it might be faulty. I'll put two 120mm exhausts in to see if it helps. I thought with it being open at the back the warm air would just get pushed out. Cheers.
Edit: And the case is Phantek P400.
