New Build Specs advice please
16 Oct 2007
London
Hi All,
I ordered a Vega 64 just today and have now decided to build a new PC, I would like advice on what to buy with a budget of £700 excluding GPU and Monitor. This is my home desktop PC which I use for occasional games, Video editing etc.
I was planning a Ryzen 7 1700 build since I can get the clocks stable @ 3.5 - 3.7 which is okay by me, will be using the stock bundled cooler.
Basically after Case , MB, CPU, RAM, SSD and PSU.
I don't like windowed case but want as small as possible with good air flow.
Please kindly help me out.
thanks in advance
@saayinla
Did you grab the Windforce for £450 ?
Don't forget any Vega card comes with AMD free 3 games bundle :)
My basket at Overclockers UK:
Total: £708.60 (includes shipping: £11.70)​
@saayinla
I got the Power colour one against the Gigabyte.
I am now thinking perhaps I should get an AIO h100 cooler instead of the stock air cooler.
I saw the spec for the above case says it supports 240mm Rad hope it wont be too tight a fit.
At the front, should be, haven't personally used as normally at the higher scale of case budget .
** AHH wait, that Power is a longer card by far
Stock cooler is pretty good , ryzen does run cooler then intel
