Hi,
I've recently built a PC for a mate of mine and am having some very strange issues which I suspect is either down to the memory or the motherboard. The memory is 2x2 4GB OCZ Gold 800mhz and the mobo is a Gigabyte EP31-DS3L.
Yesterday after piecing it together, I started to install Vista only to be greeted with a BSOD at about a quarter of the way through installation. The PC would start, but would give me a 'BIOS automatically recovering' message. After much fiddling around, I managed to install Vista, with only one stick of RAM.
As soon as I put the 2nd stick of RAM in, the problems start. Shortly after installing vista, I managed to get the PC to boot into windows with no probs with both sticks in but after restarting, it would fail to post or give me the BIOS message again.
There's an issue with one stick in particular, it's not just having 2 sticks in, it won't post with the 'bad' stick installed but is fine with the other in regardless of which socket it's in.
The thing that is confusing me is that both sticks work fine in my PC. I'm currently using them infact. Is it just a compatability issue or is it likely that the memory could be causing the problems?
Any advice or pointers appreciated. Thanks
