New build time+water
15 May 2012
Louth, lincs
Hi guys planning a new build and want to put the cpu under water and with a view to getting blocks for the gpu's if its worthwhile doing and funds allow. Already got 1 lightning, just need to sell rest of my system will put my trusty 280gtx back in for that.
Will be getting a caddie for external HDD's and will be raiding the ssd's, i dont need much space on them as i tend to only have 2-4 games installed and that would be my main use, would you change anything????
currently on 1080 monitor but plan on 27" dell by xmas, £2k max
YOUR BASKET
1 x MSI HD 7970 Lightning 3072MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** - AMD 3 for FREE Promotion £455.99
1 x XSPC RayStorm D5 RX360 WaterCooling Kit £289.68
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £263.99
1 x Asus P8Z77-V PRO Intel Z77 (Socket 1155) DDR3 Motherboard £154.99
1 x NZXT Switch 810 Big Tower Case - White £149.99
1 x Corsair Professional Series HX1050 Professional Series 1050W Modular Power Supply (CMPSU-1050HXUK) £149.99
2 x OCZ Vertex 4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (VTX4-25SAT3-128G) £104.99 (£209.98)
1 x Asus Xonar D2X 7.1 PCI-E Sound Card £84.98
1 x Patriot Viper Xtreme 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (PXD38G2400C11K) £77.99
1 x LG GP30NB20 8x Slim External DVD-RW Retail Kit (Black) £26.99
1 x AeroCool Touch 1000 4-Channel LCD Touch Panel Fan Controller £25.39
2 x Mayhems Pastel - Blueberry Blue Coolant 1L £14.99 (£29.98)
3 x Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin £13.99 (£41.97)
Total : £1,982.12 (includes shipping : £16.85).
Isn't the £5 difference between the retail CPU and the OEM worth it to you?
You get a 3 vs 1 year warranty, shiny box and a stock heatsink.
would have liked the corsair 600T case and z77 rampage gene but was told i would probably struggle to fit in the soundcard which is important to me unless i watercooled the gpu's, but wouldn't i struggle with rad space?? No hdd caddies are needed in either case.
I think you mean a paper weight and 2 years warranty, still worth the fiver though;)
No, its a 3 year warranty not 2, and the heatsink will be useful for the OP if he has a watter leak/problem or sells the chip on,the new owner hasn't got to source a heatsink.
Still got one from my 2500k! But the extra 2 years is defo worth it, really did not see that, thx
Dont know if i can ask this on here, but what do you think my current system is worth with a 280gtx installed, i have no idea!! Cpu, cooler, ram, MB, ssd are 7 months old the rest are about 5 years.
No you cant ask, there is a price check forum in the Members Market which you need 180 days and 1000 posts to access.
