Just put together a new build:
- Phenom 955 @3.2Ghz
- Gigabyte 880gm-ed2h
- Coolermaster Hyper 212 cooler
After installing windows and running orthos it seems to be a little toasty. It idles at high 20's and after 30 mins on orthos gets to high 40s and can nudge over 50.
Does this seem too high? I'm not planning on overclocking now but if I were to do so in the future (quite likely) that doesn't give me much headroom.
Airflow should be good as I've got 3 fans pushing a round a fair bit of air and the case ambient temp is low 20's.
I used a rice/pea sized amount of Arctic silver 5 and think it spread ok, although I did wiggle the heatsink round a fair bit trying to get the damn thing screwed in!
Would you be comfortable with those temps or do you think I should try again? Anyone else have a similar setup? What temps do you have?
Thanks.
Thanks.
