I've just built a new machine tonight. The specs are:
* Intel Core I7 920 2.66GHz (Nehalem) (Socket LGA1366) Processor
* Gigabyte EX58-UD4P Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
* 2 OCZ 60GB SSD's
* BFG GeForce GTX 285 OC 1024MB GDDR3 Dual DVI HDMI PCI Express - Retail with PhysX, CUDA & 3D Stereo
* Coolermaster Stacker 832 case
1) The first issue is that I cannot find out what pins go where. Does anyone know of a diagram. The only spare cables I seem to have are audio? 'hd audio', 'AC 97' plus on the same wiring a bunch of single socket pins???
2) I note that the machine can start from the internal switch but there is no monitor, monitor just goes to standby.
Basically I no longer know what I'm doing with this and need help. I'm starting to panic now.
* 2 OCZ 60GB SSD's
