Hi guys.
I've been piecing together my new build as I'm just waiting for the case now, I wanted to get everything up and running to make sure it all works and install the OS etc.
My parts are as follows:
i7 5820k
Gigabyte X99M Gaming-5 mATX board
16gb HyperX Fury DDR4 RAM 2400Mhz
Samsung 500gb 850 evo SSD
Gigabyte Windforce 970 OC
BeQuiet 600w PSU
So I hooked it all up and the issues are as follows:
1. The PC won't enter Bios. If I press delete on startup it will hang on the gigabyte logo screen (all options for BIOS, boot order etc disappear)
2. I installed Windows 7 successfully, but now whenever I start the PC with no disc it says reboot and select proper boot device. When I insert the Windows 7 disc it takes me to the installation screen. I looked at the space on the SSD and it would appear that the OS is installed judging by the missing space on the drive.
3. I got into the BIOS once by hitting F12 (select boot device) which allowed me to enter setup. CPU temp was 26 degrees, CPU was running at 3.4 and all 16Gb of memory was recognised. Since then I haven't been able to enter the BIOS this way.
Help please
i7 5820k
BeQuiet 600w PSU
Help please
