After spending the last 2 weeks trying to troubleshoot this myself and getting nowhere I was pointed in the direction of you guys. Hopefully you can suggest something I've not found by googling and poking things!
PC spec:
BeQuiet 800W Straight 10 Modular PSU
Cooler Master Closed Loop Liquid Cooler 120mm Radiator
480GB SanDisk SSD
EVGA Z170 Stinger DDR4 Mini ITX Motherboard
2 x 16GB Corsair Vengeance DDR4 Ram
Intel Core i5-6600K Skylake Processor
Deepcool Tristellar Case
AMD Radeon Hd 7970 - Sapphire
Nothing overclocked.
Running clean install of Windows10
The issue:
I recently built the above PC and when I open up Far Cry 4 I get a fairly stable 60FPS, but then after between 5-15 minutes all of a sudden the FPS drops to around 2-3FPS, I checked other games and even just watching a YouTube video where exactly the same issue occurs.
With Open Hardware Monitor running it shows that the GPU load spikes to >95% and stays there whilst the FPS drop occurs. Running Process Explorer shows that in the case of YouTube videos chrome is using all of the >95% GPU load when it spikes.
None of the temperature sensors ever read >45C with the exception of the GPU playing FC4 which still never exceeds 75C.
My current workaround is when the FPS spike hits I unplug the monitor from the GPU and plug it straight back into the GPU and all is instantly well for the next 5-15 mins before it all happens again!
Things I have tried already none of which made any difference:
All Windows updates.
Update the GPU drivers.
AMD Legacy drivers.
AMD Beta drivers.
Updated the BIOS.
Checked Windows Power settings.
Removed half the Ram (down to 1 x 16 GB).
Full format and reinstall of Windows 10.
Running with a friends Radeon 7950 which is known to work in his setup.
Putting my old 750W Corsair PSU back in.
Forced the GPU to run at max clock speed. (https://community.amd.com/thread/191820)
Ran Antivirus and Malwarebytes (both clean - not surprising on clean install)
The only thing I could find that 'fixed' this is running from the CPU through integrated Graphics...
I can provide any version numbers and any logs that you think would be useful when I get home later today!
Thanks in advance.
PC spec:
480GB SanDisk SSD
The issue:
AMD Legacy drivers.
AMD Beta drivers.
Updated the BIOS.
Thanks in advance.
