- 1 Dec 2005
hi guys,
Just put a new build together, got everything installed just now with no major issues. Just been poking around the bios and cpu-z, some things doesnt seem right.
From what i've read the 5050e (the cpu i am using) should be volted at 1.2 and not this high value. Is this just the Asus board overvolting by default? If so how do i turn it back down because as you can see, it doesn't give me many options. (just noticed the cpu-z value is different... lower but still high right?)
My second concern is the speed at which the ram runs at. These are the ocuk value ram and they should be running at DDR2 800mhz. But according to cpuz its running at 373.1 which makes it 746.2 right? So why am I 50 mhz short? Funnily enough I just looked at the bios and it says its running at 400...
Would appreciate any help and thanks in advance
RK
P.S - How are those timings for value ram?
RK
