Just started my new build and thought i would test it to see if it would power on.
I've fitted the power supply to the mobo with CPU, fan and memory. When i switch on nothing powers up.
I've tested the PSU doing a paper clip test and the fan starts ok.
As soon as i connect the 24-pin ATX connector and the 4-pin ATX_12V connector to the mobo and power on nothing happens. The CPU fan does not come on and not even the PSU fan starts.
I'm using a Corsair HX520W PSU, the Gigabyte DS3 mobo and C2D E6600 CPU.
Is it a problem with the mobo?
What else can I test?
