New Build with a Intel Core 2 Extreme X6800
24 Sep 2003
Tipperary, Ireland
Seasonic S12 Powersupply 600W
ASUS P5W DH Deluxe Digital Home Series
ZALMAN ZM CNPS9500 LED - processor cooler
2Gb DDR2 PC-6400 Platinum XTC Series Dual Channel kit
Thermaltake Kandalf Black, Aluminium Front, Super tower (Without PSU)
4 x Seagate Barracuda 7200.10 320GB SATA2 16MB 7200RPM
BenQ DVD±RW burner DW1655, 16x, Dual, LightScribe, Black, OEM
LG DVD Drive, GDR-8164RBB, 16x52, Black OEM
Still Looking for:
1. SATA2 RAID 5 Controller (Do I really need one? Do I really need RAID 5? Should I just use RAID 0?)
2. Graphics Gard (Looking for High Performance but value for money aswell)
3. Sound Card?? (Is the onboard sound good enough)
Any suggestions for this build?
My first suggestion would be don't get an x6800! Very expensive, and the performance can be easily achieved with an e6600.
Also get a scythe infinity. One of the best coolers avaliable at the moment.
For graphics card, i would go with a HIS x1900xt.
I have always used onboard sound, so i on't really know what to recommend in that department.
I might also go for the geil ultra ram.
Lan said:
i can only assume Dempsey happens to be your last name if so so is mine :D
It is :D
I've already ordered a X6800 but I could flog that and get a X6600 for $169 ex import? Could I achieve that overclock on with that cooling. I'm not getting into Water cooling.
I know they are already cranked up but I could crank it up a bit more and get my monies worth?
You can do better.
Akasa Eclipse 62 Aluminium Case & Window (BU-000-AK)
Lian-Li PC-7 PLUS
Lian-Li PC V1000 PLUS
To name a few.
Is it just me or are Lian Li very plain for the price. I know they are quality. You have to pay extra for a transparent side panel.
I like the Akasa Eclipse 62 Aluminium Case & Window, very nice, but then I have to go looking for fans, extra work on me. This research craic is hard on the brain.
Keep the idea's flying in though!
I have the same mobo and I found the onboard sound to be very poor. In GTA:SA, the engine/tyre sounds disappeared whenever it started raining (too many sounds at once) and in Broken Sword: Angel of Death, some of the voices were missing.
I installed my old Audigy 2 yesterday, and it makes a big difference. Even the XP startup sound is noticeably richer, like you can feel the bass even at low volume.
I was using the Realtek drivers from the mobo CD, so maybe there are newer drivers available, but I doubt it will improve the sound quality to the standard of a seperate sound card.
For graphics, the X1900XT gives the best high-end performance/value.
Thanks for the advice lads,
I think i'll go for the Asaka case, looks nice. Gonna read some reviews on it soon enough.
Audigy cards are gone fairly cheap so I might invest in one.
Anyone recommend a 4+ Port SATA2 RAID 5 Controller?
Its certainly not overkill for a x6800, probably just a little bit to dear for some peoples liking, but if it fits into your budget then why not, looks like top quality ram and has very nice timings as well.
Right after days of chopping and changing i'm settling on the following
Seagate Barracuda 7200.10 320GB x 4 £295.88
http://www.overclockers.co.uk/acatalog/Seagate_SATA.html#aHD_2d078_2dSE
Lian-Li PC V1000 PLUS Black Aluminium Midi-Tower £129.19
http://www.overclockers.co.uk/acatalog/LianLi_Cases.html#aCA_2d027_2dLL
Creative Sound Blaster X-Fi Xtreme Music £58.16
http://www.overclockers.co.uk/acatalog/Creative_Sound_Cards.html#aSC_2d043_2dCL
Asus P5W Deluxe WiFi £152.74
http://www.overclockers.co.uk/acatalog/Online_Catalogue_Asus_177.html#aMB_2d152_2dAS
Seasonic S12 600W Silent £93.99
http://www.overclockers.co.uk/acatalog/Seasonic_Power_Supplies.html#aCA_2d002_2dSS
Highpoint Rocket RAID 2310 £104.52
http://www.overclockers.co.uk/acatalog/SATARAID_Cards.html#aCC_2d017_2dHP
HIS ATI Radeon X1900 GT 256Mb £152.74
http://www.overclockers.co.uk/acatalog/X1900_Series.html#aGX_2d057_2dHT
Zalman CPNS-9500-LED Aero Flower £35.24
http://www.overclockers.co.uk/acatalog/Zalman_CPU_Coolers.html#aHS_2d015_2dZA
Total: £1,022.44
What do people think? Interested in opinions on the RAID controller too. I cant find decent reviews of RAID controllers
I just need a recommendation in memory please
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
Price: £169.99 (£199.74 Including VAT at 17.5%)
I would go for that memory, it performs very well.
Still Looking for:
why value for money graphics when you are going to waste money buying a 6800 chip
