New Build with OCUK X1950Pro Question
30 Jul 2007
I will be doing a new build tomorrow and I am a bit confused about the Catalyst drivers, during the Windows install process.(I have downloaded the Catalyst drivers and will copy them onto a CD)
When installing XP Pro I think that I will be prompted for a driver for the X1950, do I use the driver which came with the card, or do I use the catalyst ones.
Also I have Visual Studio 2005 which uses .net v2.0, will this allow CCC to run.
Thanks
Duncan
When installing it will install with windows VGA drivers, just let it run with those and download the cats when installed.
