GAAAAAAHHHHHH!!!
My PC went bang a few weeks back, so I've invested in new mobo/ram/CPU/video card/PSU to bring it back up to date(ish).
The new build is an AMD X2 based system (X2 4800+, MSI K9N Neo V3 http://www.msicomputer.com/product/p_spec.asp?model=K9N_Neo-F_V3&class=mb (NF 560)). I bought these from a competitor.
The memory I bought from hex on the MM here. He has good trust, so I doubt he's sent me 4 sticks of knackered RAM. It's 2x2gb Geil ULL PC6400 4-4-4-12 dual channel kits (the ones with orange heat spreaders, 4 sticks http://www.overclockers.co.uk/showproduct.php?prodid=MY-058-GL).
I built it all up, checked, double checked then triple checked EVERYTHING. Twice.
Time comes to power on. Fans whir up and stay at 100%. Blank screen, nothing. Power off/on then gets to the windows login screen and freezes. Reset and into bios I go. The RAM likes 2.1V, but the mobo defaults to 1.9. I cranked up the voltage to 2.1, but bios freezes before I can exit. After a few more tries, I managed to change/save the voltage to 2.1V. Made no difference at all. I also tried 2.15V, but the same happens. CPU voltage is fine all the time.
Cue numerous attempts to boot using all combinations of sticks of RAM in different slots, but to no avail. The PC either hangs at POST, the bios screen, or flashes a BSOD just as the XP loading screen appears, and resets itself. All 4 sticks of RAM sometimes gets me to the log in screen, but it just hangs there. No other combination gets past the BSOD as mentioned.
The only solution I can think of is to buy a different mobo (one that's known to work with the Geil) and some dirt cheap RAM and try to eliminate the problem.
Any thoughts?
Any thoughts?
