So for Christmas I decided to build my grandson a starter PC. It really is a lousy experience. 16GB DDR4 Corsair Pro 3200MHZ, Ryzen R3 3200G cpu, Gigabyrte A520M K V2 motherboard and a Mesh fishtank case. 512GB NVME Firecuda and 2 Adata 240GB SSD's that I had going spare.
It really is slow as anything. All drivers installed correctly, Windows 11 bought serial key and installed via USB. So much so I've decided to return the 3200g and ordered him a 5600GT cpu instead. I'll probably buy him a 5050RTX to go with it. PSU is a good BEQUIET 450W
PSU I had going spare.
Installing anything takes a while, I've got bitlocker on the NVME as it seemed like a good idea at the time. Bios I've flashed to FE variant which is the latest available. When I did the flash the NVME required the bit locker code to be put in which was a pain but worked OK.
Went back into the BIOS to use XMP profile and check all was well there. Are these just slow as **** anyway or will the 5600GT make any difference? I am hoping to get him something he can play Fortnite on and a few Esport titles.
In comparison my 7800x3D is a rocketship. Am I expecting too much from a cheap build?
Also rather than the 5050RTX there is a Vega 56 locally cheap that is literally going begging, worth it or no?
Thank you in advance.
