I bought these parts last week;
Phenom II x4 940 (AM2+)
Gigabyte MA790-UD4
2x2Gb G.Skill (2.0v-2.1v)
HD4890 1Gb
x2 WD Caviar Black 640Gb
I am using same PSU from my last build, an OCZ GameXstream 700W.
Basically I've put the system together and either nothing will work or a couple of fans will spin...randomly...but the system will not boot. The PSU is supposed to glow blue at the back (tacky LED) when it is running properly but when I hit the power switch it stays dark and just emits a quiet buzz.
The PSU defintely works, as I am using it right now to run this old system outside of my case. I have a couple of ideas; like my motherboard officially supports "4 x 1.8v DDR2 Modules" and my G.Skill is rated at 2.0v-2.1v. Could this default lack of juice actually cause the system to not even boot? I was assured that all I would need to do would be to enter the bios and increase the memory voltages.
Anyway, my other idea is something to do with the 12v ATX power connectors. This PSU hs 2x 4 Pin 12V power connectors which are supposed to go together in the 8-Pin ATX 12V socket on the board near the CPU....but in the manual it says when using 2 x 4Pin that you should remove the protective covers from the connectors and the socket on the motherboard. I have to say, these seems really unwise, considering they fit in as it is.
Anyone have any ideas? I'm at a loss.
Gigabyte MA790-UD4
HD4890 1Gb
