- 1 Feb 2006
- Newcastle upon Tyne
Hi, I'm trying to build the system shown below. I've put everything together and it all looks fine (I have built 3 systems now which work). But when I turn on the PSU (the switch on the back) the whole pc starts (cpu fan, case fan, hard drives and dvd drive) but nothing is shown on the monitor (btw I have tried 2 different monitors, 2 video cards and 2 PSUs so they can be eliminated).
Now, the motherboards manual says the mobo does not support 3.3V agp cards. Does anyone know what voltage these cards are? ATI 9600XT 256mb or ATI 7000 64mb
A while ago I took the heatsink off and had a look at the CPU, which looks fine. Then I had tea (about 30min break), then I changed the PSU and it worked (and put the heatsink back on), but only for 2 boots, then it had the same problem again. I have tried swapping PSUs and plugging/unplugging them in with no luck. Perhaps this suggest a overheating plroblem??
To me it looks like a motherboard problem becuase as soon as the PSU gets power all the fans spin up (without me pressing the power button - which is wired up correctly). The computer then does not send any signal to the monitor and holding down the power button does not turn it off. As if the motherboard thinks someones holding the power or reset button, but even disconnecting all the power/led plugs does not help.
Any suggestions would be greatly recieved, thank-you
---Spec---
Mobo: ASRock 939A8X-M
CPU: Amd athlon 64 3200 venice s939
Ram: 1gb value ram
Graphics: ATI 9600XT 256mb and/or ATI 7000 64mb
PSU: 500w and/or 300w
---Spec---
Ram: 1gb value ram
