- 14 Dec 2011
- England - Doncaster
hi so my build is :
Case with build in 300w psu - s-003B CIT (4 pin power to mobo)
Mobo: F2a68hm - hd2 (8 pin 12v socket)
GPU: gt 730 2gb
Cpu: amd Athlon x4 core (860k) it says on box requires discrete cpu.
Ram: x2 4gb ddr3 corsair vengeance 1600mhz.
No hd yet wanting to just check bios and things before I add it.
This is my 4th build but never built a pc with such poor specs and case so it's a it difficult.
The pc starts up and the keyboard lights up fine but my monitor gets no signal. I have the hdmi cable plugged into the gpu hdmi socket and no signal, I also tried the mobo hdmi socket to no avail.
Any ideas. I also plugged in my headphones to check if there were any beeps on start up. There wasn't. I also tried starting up with 1 stick of ram.
Ohhhh I sorted it
my god damn gpu wasn't fully plugged in.... geez so annoying. Thank you anyway guys
GPU: gt 730 2gb
Ohhhh I sorted it
