http://forums.overclockers.co.uk/showthread.php?t=17796684
Details of the parts in thread above.
Put this together today for a mate. But when I powered up I didn't get anything on the monitor. Tried 2 monitors & cables. Nothing.
Checked all connections in PC & everything seems fine. The system & CPU fans spin, the HD spins up, the DVD drive opens & the gfx card heatsink gets warm/hot. Nothing on the monitor though & I don't get a bleep (checked the 'speaker' cable from the front panel as well).
I then phone Overclockers who suggested trying different RAM combo's & failing that it sounded like a dodgy mobo. Any other ideas from you guys before I strip the whole thing down again & send back?
Cheers.
EDIT: Also noticed, after phoning OC, that the nortbridge heatsink wobbles. Should this be firmly attached?
Cheers.
I did more or less this exact same build just a few weeks back & everything was sweet.
Would be good to check to make sure but it's a lot of hassle. Besides the Northbridge heatsink is not right anyway - as soon as the board heats up it comes loose. I've checked the pins & they seem to be in okay so I'm not sure what's happening there.
