New build, wont post :(
13 Nov 2002
Scotland
Hi Guys
Just want to check I havent missed anything obvious.
Im building a little bitfenix prodigy setup based on a FM2 itx.
To cut a long story short, it wont post. No noises, beeps etc, but the fan does fire up.
Ive got it down to the mobo or CPU, and im using the following:
FM2-A75IA-E53 (new)
AMD 750k (bought on MM here)
Ive tried different ram and power to isolate those as well as using vga and HDMI just to make sure :) Also tried re-seating the cooler and checked the pins on the CPU, which all appear fine.
Any ideas gents?
Im assuming you plugged the 4pin cpu connector in ? :D I would also just double check that the ram is properly seated and go over any other connectors i.e hard drive, optical drive etc
It may be a case the motherboard may need a BIOS update to work with the CPU.
I assume you have the extra 4 pin for cpu power connected.
Yeah, mobo says it works with the cpu
4 pin connector was connected yeah :)
No optical drives etc, made sure it was bare minimum. Tried another good PSU and tried two other sticks of ram in different slots... same result.
bah you have to admit it....we wont laugh honest we have never done anything stupid while building a PC Honest *hides in a corner :)
Well...
When it first didnt work with the gfx card in, I stripped everything off bar the minimum. So, psu, ram, mobo and cpu... using the onboard vga.
However, I assume the mobo doesnt actually have onboard graphics but uses the chip gfx, which the 750k doesnt have :)
Thats my theory anyway :)
So you tried to boot your pc up without your graphics card and without the processor having any onboard GPU? :P hah.
I've done that, my pc booted fine but i was worried when my display wasnt giving any feedback, only to realise my processor didnt have integrated GPU and motherboard had no visal outputs \:
