Hi all,
Literally just put together my new build but there is no power coming through. It's a Corsair AX650, mobo is a Gigabyte GA-Z77X-D3H.
I'm pretty sure it's the PSU but just wanted to check there was no other tests I can do.
- Absolutely no response when pushing the power button (no fans, no post, no lights)
- No LED's or lights on the mobo (don't even know if it has any)
I have
- Used different power cables and wall sockets.
- Tried turning the PC on by shorting the power button pins rather than using the power button.
- Tried the paperclip test and got nothing (although I don't actually have anything plugged in but th GFX and a few disk drives)
So, dead PSU or a few more items I need to do? WOuld I get some kind of resonse from the system if it was another part broken?
Thanks!
I have
Thanks!
