New build won't power on
17 May 2011
Hi,
I've just put together a new build HTPC and I cannot for the life of me get the bugger to power on.
The specs are
I3-6100
Asus H110m-a (also tried an alternative board)
Kingston Hyper X 2133 ram
Corsair RM550X (I've tried a seasonic X series as well)
Crucial MX300
I press the power button and nothing happens. I've even tried putting a screwdriver between the power switch prongs on the motherboard and this hasn't brought it to life either. Switching the motherboard and PSU hasn't helped either, so I am assuming I am missing something.
Any ideas?
Thanks in advance.
Cheers,
Ross
The diagnostics I have done so far includes:
-Disconnecting everything and starting again.
-Switching the motherboard.
-Switching the power supply (worth noting the power supply didn't work on my working PC, but neither did my power supply from my working PC switch the new build on).
-Attempting to boot the PC without the case button (didn't work with either power supply).
Thanks for the response. I tried turning it on without the ram yesterday and it still didn't power up. Not even a single movement from the CPU fan.
Thanks for the response. No lights on the motherboard and I changed the kettle lead. The only cables that were the same were the modular cables. I do have a brand new power supply to try (another corsair rm550x), plus a new CPU fan, so I'll be trying that in the next hour or so.
You mean you tried Seasonic in that PC with Corsair's cables?
Different PSUs have different modular cabling so you should always use PSU's own cables.
Yeah being a bit of a melon, I thought they'd be standardised like ATX sizes etc. I only realised after searching Google after posting that. I shouldn't be allowed out unattended haha.
I'm just building the setup with a new psu now.
It's alive!!!! Thanks for all your help guys. Turned out the PSU was doa (and that this moron tried to use the wrong cables to test the other power unit).
