New build won't run with 4pin atx connected
28 Aug 2011
Hi guys.
I bought the following parts from overclockers this week:
£89.16 x 1 - Asus ROG Strix B350-F Gaming AMD B350 (Socket AM4) DDR4 ATX Motherboard
£132.49 x 1 - AMD Ryzen 5 Six Core 1600X 4.00GHz (Socket AM4) Processor - Retail
£132.49 x 1 - Team Group Night Hawk RGB 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - RGB Black (TF1D4
£324.99 x 1 - Inno3D GeForce GTX 1070 HerculeZ Twin X2 8192MB GDDR5 PCI-Express Graphics Card
£107.49 x 1 - Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU)
£49.99 x 1 - Kolink KL-1000M 1000W 80 Plus Bronze Modular Power Supply
£58.29 x 1 - Raijintek Orcus RGB AIO Water Cooling Unit - 120mm
£74.99 x 1 - Corsair Gaming VOID PRO RGB Wireless Premium Gaming Headset with Dolby Headphone 7.1, White
£157.49 x 1 - MSI Optix G24C 24" 1920x1080 VA FREESYNC 144Hz 1ms Curved Widescreen Gaming Monitor
£62.49 x 1 - Antec DF500 RGB Midi Tower Case - Black Window
£4.99 x 1 - OcUK Value 3m Male - Male Display Port Monitor Cable (CDLDP-003)
£116.66 x 1 - Elgato USB Customisable Stream Deck (10GAA9901)
Started the build last night. I've built around 5/6 pc before, so not exactly inexperienced but this one has got me stumped.
With everything in place, checked everything was position correctly and seated properly and following the advice from all the manuals, but when I tried to turn on, nothing happened. I double checked all connections. Everything seemed fine.
The motherboard lights up but nothing happened when I pressed the power switch.
Testing everything individually, I found that the pc will only power up when the 4pin atx connector is removed. Obviously that won't let the pc boot as no power is going to the cpu.
Anyone have any idea what is wrong?
Any help greatly appreciated.
Thanks in advance
TD
Have you connected the 8 pin EPS connector from the PSU to the connector on the top right of the board - where are you plugging in the 4 pin ATX?
Plugin the 20+4 pin and then the 8pin EPS near the CPU socket - note this is a different connector on your PSU to the 8pin PCIE you use for GFX cards etc
Guys. I'm so embarrassed. I was actually using the wrong connector. Working now. Saved a lot of heartache. Thanks so much.
