New Build Won't Work
1 Feb 2008
Hi!
Ive just put together my new build
Asus P5KC mobo
3870 hd
corsair 650W
etc.
Anyway, When I turn it on the fans on the cpu, grafix card and chassis fans give a short whizz for about a second then nothing
All the time the LED indicator is on on my mobo
Does any1 please have any idea of whats up?
Thanks
can you post your full specs please
suggestions
check everything is actually connected and connected properly
post here your MB's led indicator codes or patterns if they represent some sort of error, someone may know how to help.
google the method for testing your PSU with a paperclip and test it to see if it is the problem
it basically involves removing a jumper for a few seconds....google it and then look into your mobo manual. Knowing how to clear the cmos is schoolboy stuff for anyone wanting to build a pc
