New Build
1 Apr 2008
I was looking to build a system from scratch but i can't seem to find the option on the website.
I can only see the section where you can tweek other pre builds, is it possible to build one completely from scratch?
Yours Robbie
no ,but you can get the help you need here on the forums to help you spec and build your own from scratch.
if you are willing to put it together yourself, tell us how much you have to spend, what you need with the pc, what it would be used for and are you overclocking.
currently intel CPUs are better value for money especially when you overclock
when i said no in my previous reply, i hope you read it as no ocuk does not put systems you speced yourself together for you
