hiya chaps,
My current case seems to be suffering from poor airflow and as such I think something in it is overheating ( not bothered with temp monitoring but I'd guess the HDD as it's quite warm ) causing lockups unless I remove the side panel. Current case is an Antec SLK1650B and I think the cause of the problem is 2 fold.
1) the HDD and X1800XT are causing a semi duct effect accross the bottom of the case from the single 80mm input fan ( which doesn't seem to push huge amounts of air ).
2) the side hole pulls air over the CPU which is good for the CPU but doesn't allow much extra air into the case.
So I'm pretty sure there is little cold are getting to components other than the CPU.
I'm therefore looking for a new case to try to lower case temps.
Budget isn't high but I'll let you advise on cases without a budget restriction - just don't go silly
- did you mean the PC-7?
Just takes a little time to get setup.
