New Case and Cooler
10 Aug 2010
Somerset
I've currently got a Lian Li PC-A05NB and am thinking of selling it, and getting a new case and a CPU cooler (on stock atm). I like the Lian Li but I don't think its the best for cooling (?) and I'd rather something a little bigger.
Which is best for cooling? Looks wise I like the following (though probably can't quite afford the Cooler Master):
http://www.overclockers.co.uk/showproduct.php?prodid=CA-212-CM&groupid=701&catid=7&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-BX&groupid=701&catid=7&subcat=
and was thinking of the Gelid for cooling:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-GD&groupid=701&catid=57&subcat=1395
I have corsair vengeance ram, am I right in thinking this will be okay if I put the fan on the right way round? i.e. it will clear the cooler okay?
The plan is to properly overclock my i5 750. I know for the 2500k you can get 4.6Ghz with most chips, should I be able to get 4Ghz with my 750?
Get the Shinboi but get the windowed version . This will give you an extra fan slot and a nice window to see inside of your case. The cooling is pretty decent on this case.
The Gelid Tranquillo will be perfect and will allow you to have the memory in the right place.
