dave24 said:I`ve decided i`ve had enough of my vapochill XEII and been looking at the Antec P182 case and the Noctua NH-U12F heatsink,can anyone recommend anything better.
dave24 said:cheers for the reply,will have a look at those cases
$loth said:Haven't used the noctua or the tuniq, though I would go for the noctua due to the sounds levels, plus with the tuniq the fan is inside which is off putting to me (can't replace it, and it it breaks you've lost the whole thing).
bringerofdecay said:afaik you can remove/replace it as the top unscrews
correct me if im wrong
$loth said:Just been looking at a couple of reviews, would seem your right![]()
thought i'd heard it somewhere
