New Case Defect
26 Nov 2009
Hi. I won't tell you what case it is so it doesn't put you off, because generally the case is quite decent for its price.
The side cover is slightly bent. Would you bend it straight or make a fuss over it?
Would be rather ridiculous to send it back to the retailer for that, bend it back and save everyone the hassle.
I think I'd definitely bend that back rather than going through the hassle of the returns process. Not worth the effort for something so minor that could likely be sorted out to a very good standard in a matter of minutes.
