- 22 Mar 2007
I've got a Coolermaster CM-690II case with 2 stock fans (both 1450rpm) and 3 coolermaster silent turbine master fans (max rpm of 800). The front fan is intaking, as is the side fan, and then the two top fans and the one rear fan are exhausting hot air. I'm happy with the airflow direction but not with the noise level vs cfm. Ideally, I'd like high rpm 120mm fans that I can adjust with a fan controller. My main aim is to make my pc as quiet as possible during day-to-day tasks. I don't mind if it's louder under load as I will either have speakers or headphones on.
I'm looking for some recommendations for 120mm case fans that push a decent amount of air but can be adjusted to be very quiet. I've heard good things about the Scythe Gentle Typhoon fans and I was looking at the 1850rpm 120mm model. Is there anything that would be more suitable as case fans?
In terms of the fan controller, I need one that can control more than four fans and also has a screen, which seems fairly hard to find. I've seen this fan controller:
http://www.nesteq.net/gb/products/fancontrollers/maxzero/
Does anybody have any experience with this fan controller?
