Hi
could you recommend a case that would hold up to 6 hard drives.
its for video editing. The extra HDs are for backups and so on.
MB is Gigabyte GA-X48-DQ6
Thanks.
If you don't mine the size the Lian Li A70/A71 are great cases and have room for 10 hard drives and the choice of top or bottom psu position, great air flow and plenty of room inside.
I don't think I want a see through side. Its just for video editing, no games.
In short I want a case that will hold 6 HDs
Good air flow
Not too noisy
Hold the Noctua NH-U12P cooler
I think thats it
That's good old A71. Only difference to A70 is door which muffles noise of intake fans and components really nicely.
And with normal airflow speeds it doesn't restrict airflow in any way because of lot of holes in sides of door and slot between it and front panel.
Here's bigger image.
But thought I should ask about the Lian-Li PC-A7010B http://www.overclockers.co.uk/showproduct.php?prodid=CA-146-LL
Its about £30 more, is it worth it??. If not I'll order A70B.
The case I have now (chieftec) has a door but I keep it open all of the time.
Thanks again for your advice
